Salta al contenuto principale
Shark ION Robot R75 Side Brush Replacement
Cosa ti serve
  1. Shark ION Robot R75 Side Brush Replacement, Side Brush: passo 1, immagine 1 di 3 Shark ION Robot R75 Side Brush Replacement, Side Brush: passo 1, immagine 2 di 3 Shark ION Robot R75 Side Brush Replacement, Side Brush: passo 1, immagine 3 di 3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
Conclusione
2 Commenti
I have removed/lost my screw that went inside the side brush. Do you have screw size recommendation to replace it? Shark doesn't sell them and says the brush may fall off if I don't have my screw. Is it guaranteed that Phillips #1 Screwdriver would be able to remove screws? I have tried all types of screwdrivers and haven't found one to remove the other screw to take it to the store to find the right size to replace what I am missing.
Kell S - Replica
Our Shark AV1002AE needs a Torx T-9 to remove the screw. However we have not found a replacement screw or insert
Kathy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 169
Tutti i Tempi: 6,031
