Introduzione
The side brush motors power the two side brushes on the Shark ION Robot R75. If your Shark ION Robot still functions without side brush movement and the brushes have already been replaced, this guide will show the process of replacing a burnt out or malfunctioning side brush motor. This guide is a bit more involved than some of the other simpler guides, so be patient and follow step by step. You will want to follow this guide in the event that either your brush motors fail, or in case your charging contacts need to be replaced.
Cosa ti serve
Flip the R75 over so that the underside is facing up.
Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
Remove the battery cover.
Slowly pull the white tabs outward to remove the battery.
Make sure to review how to appropriately use special bullets. Make sure to check throughout to remove “locate” steps, and instead, just go straight to the action.
Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
Remove the battery from the device.
Here, you’re using tweezers, but you don’t indicate that in the guide steps. Instead of including the information in the special bullet, I would just integrate the tool into the actual procedure. Do you have pictures of you pushing the tab? Can they yank the wire, or do they need to pull gently? I would add a flipbook style action shot to make the procedure clearer in the pictures.
Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
I would add markup and action shots here. Which cover? Make sure to specifically identify device components.
Pull the main brush slightly to the right to remove it from the compartment.
When will you know that you’ve pulled far enough to the right? When you say remove, do you need to lift the brush up? Do you have more action shots demonstrating this procedure?
Remove the rubber end cap indicated by the red circle.
Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
The first step doesn’t seem necessary here. You can just include markup on the full shot to show the component you’re asking them to work on. Also, you don’t need to include cleaning/maintenance directions here, although you can include them in the introductions and/or the troubleshooting page.
Flip the R75 to its underside.
Make sure the R75 is shut off.
Here, the device was already oriented this way, so the directions on the side sensor with using this prerequisite make the procedure confusing. Make sure to read through all guides to make sure you don’t have these kinds of continuity errors. Also, include the battery replacement as a prerequisite for all guides, and use the system to include the prerequisites, rather than putting this information in the note.
Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
Be sure to include a markup shot showing the location of the five screws. Remove locate steps in all guides. Indicate how to remove the wheel assembly in the guide text. Use caution bullets for caution notes.
Flip the wheel assembly over and disconnect the cable connector on its underside.
Remove the drive wheel assembly.
Add markup. Remove all reassembly guide text. Indicate how to disconnect the cable, not just to do it.
Orient the device with the bottom facing up.
This photo is not helpful. Is removing the whole assembly correct procedure, or could it break the device?
Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
Remove the wheel.
Note that you’re using a plastic opening tool, not a screwdriver. Be sure to appropriately identify tools. Proofread all guide text for clarity and end punctuation. For all remaining “remove” steps, if something can be done in multiple ways, then you need to indicate how. Remove is good for screws because there’s only one way to do that. For everything else, use more detail or a stronger verb.
Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
Pull the caster assembly up from its slot in the device.
Hi I have the same model but the screws are not on the outside and there is what appears to be like a ring like part that held the caster assembly in the slot I cant pop the assembly back in and nor does that white part come out can you please help me with that
Push down on the black tab and remove the dust bin
In the first image, the device looks significantly different for Step 13 to Step 14, then the device is flipped in the second and third images. Be careful about these kinds of continuity errors.
Using a Torx TR15 screwdriver, remove the five screws from the bottom cover.
Use markup on images to show where components are. Past Step 15, here, I’m no longer marking this issue. Additionally, proofread all steps for end punctuation.
Using a Torx TR15 screwdriver, remove the five screws along the front edge of the device.
Pull the bottom part of the bump guard away from the body of the device.
What does it mean to face the device rearward?
Do you have pictures of you removing the bump guard?
Lift the top cover up from the rear of the robot to separate the top cover from the rest of the robot.
What is the difference between the two black bullets? Also, the information bullet is not necessary here.
Using a Phillips #00 screwdriver, remove the screw holding down the diagonally vented side cover.
Slide the sensor out from the base of the robot
Lift up the diagonally vented cover on the side of the robot containing the side sensor.
Disconnect the white connector from the sensor.
Using a Phillips #00 screwdriver, remove the screw on the sensor.
Remove the sensor from its mount.
Do you have a picture of you separating the components? Also, make sure to write directions as commands.
Using a Phillips #0 screwdriver, remove the two screws on either side of the motherboard.
Altre 4 persone hanno completato questa guida.
5 Commenti
What is the motor part that is being replaced?
I have a different question.
My ion 75 will clean for three minutes, and then it returns to dock. I have cleaned everything underneath but have not unscrewed anything. Popped the wheels and brushes and used Qtip on the side sensors. I charged directly from the wall (bypassing the charger) and had the same result….. three minutes cleaning and returns to dock.
Am I being premature to suspect a battery replacement is needed? This detailed article of yours has me wondering.
flea
My ion RV870 series just stopped working flashes blue max. I have checked all components and cleaned. It has a good charge. I see no dysfunction what so ever. How do I get it working again?? I'm out of ideas because everything seems to be functional and clean.
I have the Shark IQ, this was very similar and absolutely awesome. Thanks so much
Here, you have misused the reminder bullet. The note bullet would be better in this case; I would also say how to turn it off, rather than just to do it. Avoid locate steps, and instead, move straight to the information about what to do. Use markup on the images to indicate where the component is. Be careful about using “remove” without other information about how to remove it, especially if there are multiple ways to remove something.
Alex Watkins - Replica
