Salta al contenuto principale
Shark ION Robot R75 Drive Wheel Assembly Replacement
Cosa ti serve
  1. Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: passo 1, immagine 1 di 3 Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: passo 1, immagine 2 di 3 Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the robot is shut off by pressing the power button on top.
    • Flip the R75 over so that the underside is facing up.
    • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
    • Remove the battery cover.
  2. Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 2, immagine 1 di 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 2, immagine 2 di 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 2, immagine 3 di 3
    • Be careful when removing the battery, as it will still be connected to a wire.
    • Slowly pull the white tabs outward to remove the battery.
  3. Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 3, immagine 1 di 2 Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 3, immagine 2 di 2
    • Be careful when removing the connector, as the part can break if too much force is used.
    • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
    • Remove the battery from the device.
  4. Shark ION Robot R75 Drive Wheel Assembly Replacement, Drive Wheel Assembly: passo 4, immagine 1 di 1
    • Flip the R75 to its underside.
    • Make sure the R75 is shut off.
    • For extra security, disconnect the battery by following the prerequisite guide.
  5. Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 5, immagine 1 di 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 5, immagine 2 di 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 5, immagine 3 di 3
    • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
    • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
    • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
  6. Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 6, immagine 1 di 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 6, immagine 2 di 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: passo 6, immagine 3 di 3
    • Flip the wheel assembly over and disconnect the cable connector on its underside.
    • Remove the drive wheel assembly.
    • Repeat this process for the other side if necessary.
Conclusione
Altre 3 persone hanno completato questa guida.
6 Commenti
Where I can buy the Shark ION Robot R75 Drive Wheel Assembly Replacement?
Thanks for your help!
xoxolo - Replica
Do you know what the drive wheel motor cable is (see Step 6)? It's a 6 pin to 5 pin and the grooves are on the thin side and pitch of ~1.4mm. Possible a JST ZH?
Seth T - Replica
I appreciate the step-by-step instructions with pictures... this was very helpful. However, my rv750 doesn't have the screws by the wheel assembly.
I've removed the screws, but it appears that I will need to separate the bottom from the top to access the wheel assemblies. Do you have a step=by step for the rv750 that has the wheel assembly enclosed?
RandiB - Replica
The right wheel ass has a small gear striped inside, can you buy the small gears to repair the wheel drive?
Jerry Rotenberry - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 50
Tutti i Tempi: 9,729
