Salta al contenuto principale
Shark ION Robot R75 Caster Wheel Replacement
Cosa ti serve
  1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: passo 1, immagine 1 di 1
    • Orient the device with the bottom facing up.
  2. Shark ION Robot R75 Caster Wheel Replacement: passo 2, immagine 1 di 3 Shark ION Robot R75 Caster Wheel Replacement: passo 2, immagine 2 di 3 Shark ION Robot R75 Caster Wheel Replacement: passo 2, immagine 3 di 3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  3. Shark ION Robot R75 Caster Wheel Replacement: passo 3, immagine 1 di 3 Shark ION Robot R75 Caster Wheel Replacement: passo 3, immagine 2 di 3 Shark ION Robot R75 Caster Wheel Replacement: passo 3, immagine 3 di 3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
Conclusione
Un commento
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 116
Tutti i Tempi: 4,662
