Salta al contenuto principale
Shark ION Robot 750 Motor Replacement
Cosa ti serve
  1. Shark ION Robot 750 Motor Replacement, Outer Shell: passo 1, immagine 1 di 3 Shark ION Robot 750 Motor Replacement, Outer Shell: passo 1, immagine 2 di 3 Shark ION Robot 750 Motor Replacement, Outer Shell: passo 1, immagine 3 di 3
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Motor Replacement: passo 2, immagine 1 di 2 Shark ION Robot 750 Motor Replacement: passo 2, immagine 2 di 2
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Motor Replacement: passo 3, immagine 1 di 2 Shark ION Robot 750 Motor Replacement: passo 3, immagine 2 di 2
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Motor Replacement: passo 4, immagine 1 di 2 Shark ION Robot 750 Motor Replacement: passo 4, immagine 2 di 2
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Motor Replacement: passo 5, immagine 1 di 3 Shark ION Robot 750 Motor Replacement: passo 5, immagine 2 di 3 Shark ION Robot 750 Motor Replacement: passo 5, immagine 3 di 3
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Motor Replacement: passo 6, immagine 1 di 1
    • Lift the outer shell to expose the Shark’s interior.
  7. Shark ION Robot 750 Motor Replacement, Motor: passo 7, immagine 1 di 2 Shark ION Robot 750 Motor Replacement, Motor: passo 7, immagine 2 di 2
    • Be sure to disconnect any source of power related to your vacuum for safety purposes.
    • Remove the bolt to detach the motor by using the Phillips #0 screwdriver.
    • The motor is connected to the motherboard by this group of wires. Gently pull on the white plug to disconnect the wires.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 184
