Salta al contenuto principale
Shark ION Robot 750 Charging Dock Motherboard Replacement
Cosa ti serve
  1. Shark ION Robot 750 Charging Dock Motherboard Replacement, Charging Dock: passo 1, immagine 1 di 1
    • Remove the three Torx T6 screws on the underside of the charging dock.
    • Lift off the lower case.
  2. Shark ION Robot 750 Charging Dock Motherboard Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew the four screws inside.
  3. Shark ION Robot 750 Charging Dock Motherboard Replacement: passo 3, immagine 1 di 2 Shark ION Robot 750 Charging Dock Motherboard Replacement: passo 3, immagine 2 di 2
    • Gently push in the tabs to remove the sensor housing.
  4. Shark ION Robot 750 Charging Dock Motherboard Replacement: passo 4, immagine 1 di 1
    • Unplug the two wires going into the motherboard, then gently lift the motherboard up and out of its slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 71
