Salta al contenuto principale
Shark ION Robot 750 Battery Replacement
Cosa ti serve
  1. Shark ION Robot 750 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the device is completely powered off before working.
    • On the bottom of the vacuum, unscrew both sides of the vacuum cover using a Phillips screwdriver.
    • Gently lift and remove the cover.
  2. Shark ION Robot 750 Battery Replacement: passo 2, immagine 1 di 2 Shark ION Robot 750 Battery Replacement: passo 2, immagine 2 di 2
    • Grip both of the battery pull tabs and lift the battery out.
    • Be careful when lifting the battery out because it is still connected to the motherboard.
  3. Shark ION Robot 750 Battery Replacement: passo 3, immagine 1 di 2 Shark ION Robot 750 Battery Replacement: passo 3, immagine 2 di 2
    • To disconnect the battery, firmly squeeze down on the marked tabs, then pull the connector out of the socket.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 109
