Salta al contenuto principale
Shark Flex DuoClean Suction Motor Replacement
Cosa ti serve
  1. Shark Flex DuoClean Suction Motor Replacement, Dust Cup: passo 1, immagine 1 di 2 Shark Flex DuoClean Suction Motor Replacement, Dust Cup: passo 1, immagine 2 di 2
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Suction Motor Replacement, Suction Motor: passo 2, immagine 1 di 1
    • Remove the five 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  3. Shark Flex DuoClean Suction Motor Replacement: passo 3, immagine 1 di 1
    • Use the iFixit opening tool to remove the top component.
  4. Shark Flex DuoClean Suction Motor Replacement: passo 4, immagine 1 di 1
    • Remove the two 15mm screws by twisting counterclockwise using the T10 Torx screwdriver.
  5. Shark Flex DuoClean Suction Motor Replacement: passo 5, immagine 1 di 1
    • Remove the two 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  6. Shark Flex DuoClean Suction Motor Replacement: passo 6, immagine 1 di 1
    • Remove the two 15 mm screws holding the motor cover by twisting counterclockwise with a T10 Torx screwdriver.
  7. Shark Flex DuoClean Suction Motor Replacement: passo 7, immagine 1 di 1
    • Cut the zip ties holding the motor using the wire cutter.
  8. Shark Flex DuoClean Suction Motor Replacement: passo 8, immagine 1 di 1
    • Cut the wires using the wire cutters to completely remove the motor.
    • For reassembly, use the soldering guide in the Introduction.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S17-G5, White Fall 2018 Membro di Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Membri
14 Guide realizzate
Un commento
how i need to know how to re connect the wires on replacing a new motor, my model is similar HV321.
andrea - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,480
