Salta al contenuto principale
Introduzione
Remove the brush roll if there is debris blocking it.
  1. Open the garage door by sliding both of the release buttons away from you. Lift off the garage door.
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Use the tab on the right side to lift out the soft roller. Use the tab on the right side to lift out the soft roller.
    • Use the tab on the right side to lift out the soft roller.
Conclusione
caoimhe
Membro da: 08/10/2018
787 Reputazione
4 Guide realizzate
Cal Poly, Team S17-G5, White Fall 2018 Membro di Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Membri
14 Guide realizzate
There’s nothing blocking the soft roller in mine. I can spin it by hand. Only the regular brush roll spins. Now what?
Keith Sauer - Replica
I have the same problem. The gear that is connected to the motor that spins the soft brush roller is stripped. The shaft spins but the inside of the gear is stripped therefore it doesnt turn the soft brush roller. I cannot find the replacement part
Bill Pucher - Replica
Having this same problem
Keona Taylor -
Same here…no blockage, but won’t spin
tbridge - Replica
I also have the same problem. No blockage. The brush roller works but the soft roller does not spin.
Gina - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 122
Tutti i Tempi: 4,158
