Introduzione
Remove the brush roll if there is debris blocking it.
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
20 Commenti
There’s nothing blocking the soft roller in mine. I can spin it by hand. Only the regular brush roll spins. Now what?
I have the same problem. The gear that is connected to the motor that spins the soft brush roller is stripped. The shaft spins but the inside of the gear is stripped therefore it doesnt turn the soft brush roller. I cannot find the replacement part
Having this same problem
