Introduzione
This guide will show you how to take apart the fan to remove the Printed Circuit Board.
Parti
Nessuna parte richiesta.
Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
  • Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
  • Do this by unscrewing from left-to-right then pull the screws out of the back of the fan
Aggiungi Commento
Pull the front and back cover apart.
  • Pull the front and back cover apart.
  • Be careful not to pull the front cover off completely because it holds the wires.
Aggiungi Commento
  • Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
  • Make sure the fan is unplugged while removing the circuit board as you may get shocked.
  • To remove the screws, unscrew in a left-to-right fashion at an angle to make sure that the wires do not get tangled.
Aggiungi Commento
  • Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
Aggiungi Commento
  • Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
  • Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
Aggiungi Commento
Conclusione
Mateo Begue
Membro da: 26/09/2012
78 Reputazione
2 Guide realizzate
Cal Poly, Team 15-46, Forte Fall 2012 Membro di Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 809
