Salta al contenuto principale
Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement
Cosa ti serve
  1. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement, PCB (Printed Circuit Board): passo 1, immagine 1 di 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: passo 2, immagine 1 di 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: passo 3, immagine 1 di 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: passo 4, immagine 1 di 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: passo 5, immagine 1 di 2 Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: passo 5, immagine 2 di 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
Conclusione
Mateo Begue
Membro da: 09/26/12
102 Reputazione
2 Guide realizzate
Cal Poly, Team 15-46, Forte Fall 2012 Membro di Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,484
