Salta al contenuto principale
SereneLife Treadmill SLFTRD20 Belt Adjustment
Cosa ti serve
  1. SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 1, immagine 1 di 2 SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 1, immagine 2 di 2
    • Turn on the main power switch.
  2. SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 2, immagine 1 di 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 2, immagine 2 di 2
    • Begin by pressing the "Start" button on the machine.
    • Let the treadmill belt run at the lowest setting.
  3. SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 3, immagine 1 di 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 3, immagine 2 di 2
    • In order to locate the roller adjustment bolts, try locating the rear left cover and rear right cover.
  4. SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 4, immagine 1 di 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 4, immagine 2 di 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 4, immagine 3 di 3
    • Remove the attached rear left and right covers from the treadmill.
    • After removing the rear covers, you'll be able to see the adjustment bolts.
  5. SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 5, immagine 1 di 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 5, immagine 2 di 2
    • Before we begin it's important to determine which side the belt is shifting towards.
    • If the belt is shifting to the right, then turn the right adjustment bolt to turn 1/4 clockwise. If the belt is shifting to the left, then turn the left adjustment bolt to turn 1/4 clockwise.
    • Place the Allen wrench in the left rear roller bolt.
    • Turn the left roller bolt adjustment to turn one-fourth clockwise.
    • Now stop and wait for the belt to begin to center itself.
    • You must wait for the belt to re-center between each adjustment to ensure that you do not overcorrect the belt.
  6. SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 6, immagine 1 di 1
    • In order to fix the slipping belt during use, we need to turn off and unplug the Treadmill.
  7. SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 7, immagine 1 di 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 7, immagine 2 di 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 7, immagine 3 di 3
    • Place the Allen wrench in the left roller bolt and turn it 1/4 clockwise to tighten the belt.
    • Repeat on the right side of the roller bolt in the same way.
  8. SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 8, immagine 1 di 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: passo 8, immagine 2 di 2
    • Attach the rear covers onto the left side and right side of the frames.
    • Turn the main power switch back on and run the treadmill at the lowest speed.
    • Run on the treadmill to determine if the belt is still slipping or not.
    • Repeat this procedure until the belt no longer slips.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,056
