Salta al contenuto principale
Separating Main Board
Cosa ti serve
  1. Separating Main Board, Remove Battery: passo 1, immagine 1 di 3 Separating Main Board, Remove Battery: passo 1, immagine 2 di 3 Separating Main Board, Remove Battery: passo 1, immagine 3 di 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. Separating Main Board, Remove Trigger Buttons: passo 2, immagine 1 di 2 Separating Main Board, Remove Trigger Buttons: passo 2, immagine 2 di 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. Separating Main Board, Remove Screws: passo 3, immagine 1 di 2 Separating Main Board, Remove Screws: passo 3, immagine 2 di 2
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. Separating Main Board, Unclip Covers: passo 4, immagine 1 di 3 Separating Main Board, Unclip Covers: passo 4, immagine 2 di 3 Separating Main Board, Unclip Covers: passo 4, immagine 3 di 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. Separating Main Board, Separate Covers: passo 5, immagine 1 di 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. Separating Main Board, Remove Ribbon Cable: passo 6, immagine 1 di 3 Separating Main Board, Remove Ribbon Cable: passo 6, immagine 2 di 3 Separating Main Board, Remove Ribbon Cable: passo 6, immagine 3 di 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. Separating Main Board, Remove Screws: passo 7, immagine 1 di 3 Separating Main Board, Remove Screws: passo 7, immagine 2 di 3 Separating Main Board, Remove Screws: passo 7, immagine 3 di 3
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
  8. Separating Main Board, Separate Main Board: passo 8, immagine 1 di 3 Separating Main Board, Separate Main Board: passo 8, immagine 2 di 3 Separating Main Board, Separate Main Board: passo 8, immagine 3 di 3
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
Conclusione
Brian W
Membro da: 12/21/11
1.290 Reputazione
8 Guide realizzate
Un commento
if you need a replacement ribbon the specs are
length: 70mm
pitch: 0.5mm
pins: 20
forward side pinning (that means the contacts are on the same side)
some listings add the total width, thats 20.5mm
Max R. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 531
