Salta al contenuto principale
Separate headstock & neck of Rock Band Fender Stratocaster
Cosa ti serve
  1. Separate headstock & neck of Rock Band Fender Stratocaster, Forewarning: passo 1, immagine 1 di 1
    • This is the version of the guitare I have based this guide on. Your mileage may vary depending on your country, the batch of your guitar, etc.
  2. Separate headstock & neck of Rock Band Fender Stratocaster, First look: passo 2, immagine 1 di 1
    • Take your guitar.
    • Turn it around in a glorious rock'n'roll motion.
    • Take a look at the screws at the back, and fetch a Phillips screwdriver with the appropriate size.
  3. Separate headstock & neck of Rock Band Fender Stratocaster, Open the headstock: passo 3, immagine 1 di 1
    • Unscrew the 4 screws at the back of the headstock.
    • You can also unscrew the screw at the top of the neck.
    • You don't have to do this last step, but it might give you a bit more wiggle room later on.
  4. Separate headstock & neck of Rock Band Fender Stratocaster, Remove the metal plate: passo 4, immagine 1 di 1
    • A metal plate hides the insertion of the neck into the headstock.
    • Unscrew the tiny tiny Phillips screw with the appropriate Phillips screwdriver.
    • It's the only things that holds the metal plate in place at this stage.
    • Without the screw, the metal plate can be pulled out without any resistance.
  5. Separate headstock & neck of Rock Band Fender Stratocaster, Preparing separation: passo 5, immagine 1 di 1
    • Now you can see why this headstock is pretty impossible to pull back : there are 2 metal bits preventing it from sliding off.
    • Unswcrew the 2 shiny screws at the top of the neck.
    • Without them, we will have more wiggle room to separate the headstock from the neck.
  6. Separate headstock & neck of Rock Band Fender Stratocaster, Separation: passo 6, immagine 1 di 1
    • With the neck screw removed, you should be able to slightly separate the 2 half of the neck at its top.
    • But one half of the neck probably stays stuck under the 2 metal bits.
    • That's OK: using your nails or a flat head screwdriver, just pull up the 2 metal bits, they shouldn't resist too much.
    • You can now be able to separate the headstock from the neck pretty easily.
  7. Separate headstock & neck of Rock Band Fender Stratocaster, Putting the neck back together: passo 7, immagine 1 di 1
    • If you have removed it, but back the external screw at the top of the neck.
    • Put back the 2 shiny screws at the very top of the neck.
  8. Separate headstock & neck of Rock Band Fender Stratocaster, Putting the headstock back together: passo 8, immagine 1 di 1
    • Put back the 2 metal bits, making sure you keep the proper orientation.
    • If you don't put them back in position, you will be able to engage and separate the headstock and the neck without having to dismantle everything again.
    • Put back the metal plate, and screw back the little screw that holds it.
    • Close the headstock.
    • Screw back the four headstock screws.
    • You're done! :)
Linea Traguardo
Piero
Membro da: 10/30/12
92 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 117
Tutti i Tempi: 9,784
