Salta al contenuto principale
Sennheiser RS120 Battery Replacement
Cosa ti serve
  1. Sennheiser RS120 Battery Replacement, Ear Pad: passo 1, immagine 1 di 3 Sennheiser RS120 Battery Replacement, Ear Pad: passo 1, immagine 2 di 3 Sennheiser RS120 Battery Replacement, Ear Pad: passo 1, immagine 3 di 3
    • Grip the ear pad with one hand and steady the headset on the other.
    • Twist the ear pad counterclockwise, then lift the ear pad off after about an eighth of an inch of the turn.
    • Replace the old ear pad with a new ear pad.
  2. Sennheiser RS120 Battery Replacement, Battery: passo 2, immagine 1 di 2 Sennheiser RS120 Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Twist the left ear pad counterclockwise to reveal the battery compartment within the headphone.
    • To remove batteries, push inward and lift up.
    • The battery should be able to pop out.
Conclusione
Altre 15 persone hanno completato questa guida.
Gayle Dunham
Membro da: 03/03/10
375 Reputazione
1 Guida realizzata
7 Commenti
Thanks for the information - this made changing the batteries a snap.
Jim K - Replica
Extremely helpful. Thank you!
-Randy N
Randy - Replica
I own three sets and one quit working. As it turns out that the rechargeable batteries in that one set need replacing.
Until I purchase some rechargeable batteries, I am using standard AAA batteries and just have to remember NOT to put the headset back on the cradle.
Thanks for the info on how to access the batteries !
mcgilljp - Replica
Thanks! You solved my mystery.
Marilyn Carini - Replica
Good information, I wouldn’t have had a clue without it. Many thanks
Geoff Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 126
Tutti i Tempi: 44,935
