Salta al contenuto principale
Sega Master System Model 2 Disassembly
Cosa ti serve
Panoramica Video
  1. Sega Master System Model 2 Disassembly, The Case: passo 1, immagine 1 di 1
    • Take out the 5 screws at the bottom
  2. Sega Master System Model 2 Disassembly, RF Shield: passo 2, immagine 1 di 1
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: passo 3, immagine 1 di 1
    • Remove the 2 screws thats holding the cartridge slot down
  4. Sega Master System Model 2 Disassembly, The End: passo 4, immagine 1 di 1
    • Congratulations! You have opened your Sega Master System Model 2!
Conclusione
Screenshots taken from a video by Global Garage
Altre 3 persone hanno completato questa guida.
Krisow
Membro da: 10/18/17
605 Reputazione
2 Guide realizzate
3 Commenti
This is in the wrong section.
Owen Ready - Replica
Nope, its in the Sega Master System area.
Krisow -
Not a Master System
Chad Luciano - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 39
Tutti i Tempi: 2,335
