Introduzione
This guide will help you remove the batteries in your controller. This is a relatively simple guide, and you’ll only need a Phillips #000 screwdriver to complete the process.
Strumenti
Parti
Nessuna parte specificata.
Using a Phillips #000 screwdriver, unscrew the single screw located on the battery cover. Remove the battery cover and set it aside.
If batteries are in the battery slots and need to be replaced, then remove the old batteries by pressing them in and compressing the spring until there is enough space to take them out.
Insert two fresh batteries into each one of the slots by pushing the indicated negative end of the battery against the spring.
Un commento
any idea where i can find a schematic for the contoller board. I just bought one of these second hand and the wireless controller won’t connect to the system. I took it apart and it’s missing a small resistor.
