Salta al contenuto principale
Sega Genesis Flashback Controller Batteries Replacement
Cosa ti serve
  1. Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: passo 1, immagine 1 di 2 Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: passo 1, immagine 2 di 2
    • Using a Phillips #000 screwdriver, unscrew the single screw located on the battery cover. Remove the battery cover and set it aside.
    • The screw does not detach from the battery cover, so do not attempt to separate them.
  2. Sega Genesis Flashback Controller Batteries Replacement: passo 2, immagine 1 di 2 Sega Genesis Flashback Controller Batteries Replacement: passo 2, immagine 2 di 2
    • If batteries are in the battery slots and need to be replaced, then remove the old batteries by pressing them in and compressing the spring until there is enough space to take them out.
    • Insert two fresh batteries into each one of the slots by pushing the indicated negative end of the battery against the spring.
    • All AAA batteries have “+” and “-” symbols on each end of the batteries to denote the positive and negative ends.
Conclusione
Altre 2 persone hanno completato questa guida.
Omar Shorab
Membro da: 04/23/18
261 Reputazione
2 Guide realizzate
Cal Poly, Team S24-G12, Maness Spring 2018 Membro di Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Membri
10 Guide realizzate
Un commento
any idea where i can find a schematic for the contoller board. I just bought one of these second hand and the wireless controller won’t connect to the system. I took it apart and it’s missing a small resistor.
Scott Phaneuf - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 2,676
