Introduzione
This guide will help you disassemble your Sega Genesis II 6 button controller. You will need a Phillips #00 screwdriver to complete this guide.
This specific model was released in 1992/93, at the same time as the Sega Genesis II. However, it is also compatible with the Sega Genesis I
Cosa ti serve
Flip the controller upside down.
Using a Phillips #00 screwdriver, remove the five screws holding the controller back cover in place.
Remove the motherboard from the controller body, after releasing the rubber part that holds the cable in the controller body
In order to disassemble the directional cross, it is necessary to levergentlypreferably with a plastic Spudger, under the 4 retaining tabs.
Then, push in the central hole with a fine tool (here a screwdriver), in order to undo the assembly
Follow these steps in reverse order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
100%
tayola ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
