Salta al contenuto principale
Sega Game Gear Headphone Jack/Volume Wheel Replacement
Cosa ti serve
  1. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Battery: passo 1, immagine 1 di 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Headphone Jack/Volume Wheel Replacement: passo 2, immagine 1 di 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Case: passo 3, immagine 1 di 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Headphone Jack/Volume Wheel Replacement: passo 4, immagine 1 di 1
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Headphone Jack/Volume Wheel Replacement: passo 5, immagine 1 di 2 Sega Game Gear Headphone Jack/Volume Wheel Replacement: passo 5, immagine 2 di 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Headphone Jack/Volume Wheel Replacement: passo 6, immagine 1 di 3 Sega Game Gear Headphone Jack/Volume Wheel Replacement: passo 6, immagine 2 di 3 Sega Game Gear Headphone Jack/Volume Wheel Replacement: passo 6, immagine 3 di 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Headphone Jack/Volume Wheel: passo 7, immagine 1 di 2 Sega Game Gear Headphone Jack/Volume Wheel Replacement, Headphone Jack/Volume Wheel: passo 7, immagine 2 di 2
    • Unscrew the screws to remove the metal covering.
  8. Sega Game Gear Headphone Jack/Volume Wheel Replacement: passo 8, immagine 1 di 1
    • The screws that need to be removed are missing from this picture.
    • Remove the two screws from the highlighted locations.
Conclusione
Brandon Page
Membro da: 04/15/10
179 Reputazione
2 Guide realizzate
Cal Poly, Team 28-33, Regan Spring 2010 Membro di Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 23
Tutti i Tempi: 6,938
