Salta al contenuto principale
Sega Dreamcast Power Supply Replacement
Cosa ti serve
  1. Sega Dreamcast Power Supply Replacement, Expansion Bay: passo 1, immagine 1 di 2 Sega Dreamcast Power Supply Replacement, Expansion Bay: passo 1, immagine 2 di 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Power Supply Replacement: passo 2, immagine 1 di 3 Sega Dreamcast Power Supply Replacement: passo 2, immagine 2 di 3 Sega Dreamcast Power Supply Replacement: passo 2, immagine 3 di 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Power Supply Replacement, Top Cover: passo 3, immagine 1 di 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Power Supply Replacement: passo 4, immagine 1 di 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Power Supply Replacement, Power Supply: passo 5, immagine 1 di 2 Sega Dreamcast Power Supply Replacement, Power Supply: passo 5, immagine 2 di 2
    • Unplug the device from the outlet. If you have just powered off the system, allow a few minutes for the capacitors to discharge before you begin working.
    • Remove the white female pin head by pinching and lifting directly up on the harness.
    • Remove the two Philips #02 screws from the board.
    • Remove the power board. Using both hands, gently lift the power board away from the console without damaging the male pin head
  6. Sega Dreamcast Power Supply Replacement: passo 6, immagine 1 di 2 Sega Dreamcast Power Supply Replacement: passo 6, immagine 2 di 2
    • Remove the unit. Carefully remove the power board from the console by lightly grasping the board by the edge and lifting directly upward.
    • Remove the two 10mm #02 Philips screws to detach the switch module from the console.
    • Purchase a replacement power board.
Conclusione
Altre 6 persone hanno completato questa guida.
Jacks216
Membro da: 11/25/09
103 Reputazione
1 Guida realizzata
Cal Poly, Team 5-1, Regan Fall 2009 Membro di Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 72
Tutti i Tempi: 17,344
