Salta al contenuto principale
Introduzione
This guide details how to replace a failed GD-ROM drive with a new working drive.
Be sure to replace the GD-ROM with one corresponding to your model number. Refer to the Top Cover Disassembly Guide for instructions on where to find your model number.
Problem with this guide: The photos incorrectly show the power supply has been removed.
Parti
Nessuna parte specificata.
  1. Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  6. Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board. Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  7. Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board. Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  8. Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket. The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  9. When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base. Remove the GD-ROM by gently lifting it from its base.
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  10. Replace the bad GD-ROM drive with a functional one. Replace the bad GD-ROM drive with a functional one.
    • Replace the bad GD-ROM drive with a functional one.
  11. Secure the new GD-ROM drive to the console with the Philips #2 screws. Secure the new GD-ROM drive to the console with the Philips #2 screws.
    • Secure the new GD-ROM drive to the console with the Philips #2 screws.
  12. Connect the three GD-ROM cables to the logic board. Connect the GD-ROM data ribbon to the logic board. Connect the GD-ROM data ribbon to the logic board.
    • Connect the three GD-ROM cables to the logic board.
    • Connect the GD-ROM data ribbon to the logic board.
Linea Traguardo
Altre 6 persone hanno completato questa guida.
Thorr686
Membro da: 06/11/2009
388 Reputazione
2 Guide realizzate
Cal Poly, Team 5-1, Regan Fall 2009 Membro di Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membri
18 Guide realizzate
If only it was that simple Sega screwed U.K gamers over with the fact we have to buy totally new consoles due to the wires of the disk drive being soldered in rather than clipped in.
Anthony Salmon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 116
Tutti i Tempi: 24,396
