Salta al contenuto principale
Sega Dreamcast Fan Replacement
Cosa ti serve
  1. Sega Dreamcast Fan Replacement, Expansion Bay: passo 1, immagine 1 di 2 Sega Dreamcast Fan Replacement, Expansion Bay: passo 1, immagine 2 di 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Fan Replacement: passo 2, immagine 1 di 3 Sega Dreamcast Fan Replacement: passo 2, immagine 2 di 3 Sega Dreamcast Fan Replacement: passo 2, immagine 3 di 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Fan Replacement, Top Cover: passo 3, immagine 1 di 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Fan Replacement: passo 4, immagine 1 di 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Fan Replacement, Fan: passo 5, immagine 1 di 1
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  6. Sega Dreamcast Fan Replacement: passo 6, immagine 1 di 1
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  7. Sega Dreamcast Fan Replacement: passo 7, immagine 1 di 2 Sega Dreamcast Fan Replacement: passo 7, immagine 2 di 2
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  8. Sega Dreamcast Fan Replacement, Fan: passo 8, immagine 1 di 2 Sega Dreamcast Fan Replacement, Fan: passo 8, immagine 2 di 2
    • Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
    • Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
Conclusione
Altre 4 persone hanno completato questa guida.
Thorr686
Membro da: 11/06/09
472 Reputazione
2 Guide realizzate
Cal Poly, Team 5-1, Regan Fall 2009 Membro di Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 58
Tutti i Tempi: 18,841
