Salta al contenuto principale
Sega CD CD Tray Replacement
Cosa ti serve
  1. Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: passo 1, immagine 1 di 2 Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: passo 1, immagine 2 di 2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD CD Tray Replacement: passo 2, immagine 1 di 1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD CD Tray Replacement: passo 3, immagine 1 di 1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD CD Tray Replacement: passo 4, immagine 1 di 1
    • Lift from the left side to remove the top of the case.
  5. Sega CD CD Tray Replacement: passo 5, immagine 1 di 1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD CD Tray Replacement: passo 6, immagine 1 di 1
    • Lift the top of the case to remove the cover.
  7. Sega CD CD Tray Replacement: passo 7, immagine 1 di 1
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD CD Tray Replacement, CD Tray: passo 8, immagine 1 di 2 Sega CD CD Tray Replacement, CD Tray: passo 8, immagine 2 di 2
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  9. Sega CD CD Tray Replacement: passo 9, immagine 1 di 2 Sega CD CD Tray Replacement: passo 9, immagine 2 di 2
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  10. Sega CD CD Tray Replacement: passo 10, immagine 1 di 2 Sega CD CD Tray Replacement: passo 10, immagine 2 di 2
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  11. Sega CD CD Tray Replacement: passo 11, immagine 1 di 1
    • Carefully unplug the wire connected to optical reader.
  12. Sega CD CD Tray Replacement: passo 12, immagine 1 di 2 Sega CD CD Tray Replacement: passo 12, immagine 2 di 2
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  13. Sega CD CD Tray Replacement: passo 13, immagine 1 di 1
    • Carefully remove the CD tray from circuit board.
Conclusione
sskyllin
Membro da: 10/18/10
21 Reputazione
2 Guide realizzate
Cal Poly, Team 5-14, Maness Fall 2010 Membro di Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 51
Tutti i Tempi: 9,616
