Salta al contenuto principale
Sears Craftsman 315.109020 Blade/ Blade Cover Replacement
Cosa ti serve
  1. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: passo 1, immagine 1 di 2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: passo 1, immagine 2 di 2
    • Although this is not a difficult fix, it can definitely make a mess.
    • Lay down a dirty towel or work rag and place the saw on top of the towel.
    • Handle the saw with care and avoid placing your hands on or near the blade when possible.
  2. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 2, immagine 1 di 3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 2, immagine 2 di 3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 2, immagine 3 di 3
    • Use the crescent wrench to remove the hex washer head screw and the washer.
    • Gently lift the blade up and pull it off of the internal threaded shaft.
    • If the hex washer head screw, or the entire blade spins as you turn the wrench, a quick jerk of the crescent wrench should loosen the screw.
    • Although many screws loosen in the clockwise direction, the hex washer head screw on this circular saw loosens in the counter-clockwise direction.
  3. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 3, immagine 1 di 2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 3, immagine 2 di 2
    • Lift up on the blade cover until it unsnaps from the washer.
    • The blade cover will come off easier if the bulk of the cover is facing away from the saw.
Conclusione
Blake Avant
Membro da: 09/29/15
218 Reputazione
2 Guide realizzate
Cal Poly, Team 17-4, Green Fall 2015 Membro di Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,006
