Salta al contenuto principale
Samsung Galaxy Tab 2 10.1 Battery Disconnect
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Samsung Galaxy Tab 2 10.1 Battery Disconnect, Back Cover: passo 1, immagine 1 di 2 Samsung Galaxy Tab 2 10.1 Battery Disconnect, Back Cover: passo 1, immagine 2 di 2
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Samsung Galaxy Tab 2 10.1 Battery Disconnect: passo 2, immagine 1 di 2 Samsung Galaxy Tab 2 10.1 Battery Disconnect: passo 2, immagine 2 di 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Battery Disconnect, Battery Disconnect: passo 3, immagine 1 di 1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Battery Disconnect: passo 4, immagine 1 di 3 Samsung Galaxy Tab 2 10.1 Battery Disconnect: passo 4, immagine 2 di 3 Samsung Galaxy Tab 2 10.1 Battery Disconnect: passo 4, immagine 3 di 3
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
Disconnected the battery, checked the contacts, reconnected it. As soon as I reconnected the battery I could smell and feel heat from the two silver areas on the MB (guessing RAM/Processors are under there). Still doesn't turn on. Any ideas?
Glenn G - Replica
Those pictures are of a Galaxy Note, T-8013, not a Tab 2.
Brian Clancy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,058
