Salta al contenuto principale
Schecter Demon-7 Pickup Selector Switch Replacement
Cosa ti serve
  1. Schecter Demon-7 Pickup Selector Switch Replacement, Pickup Selector Switch: passo 1, immagine 1 di 1
    • Note the position that the selector switch is in when the guitar has intermittent or no signal.
  2. Schecter Demon-7 Pickup Selector Switch Replacement: passo 2, immagine 1 di 2 Schecter Demon-7 Pickup Selector Switch Replacement: passo 2, immagine 2 di 2
    • Remove the retaining nut that holds the pickup selector switch to the guitar.
  3. Schecter Demon-7 Pickup Selector Switch Replacement: passo 3, immagine 1 di 1
    • Place the guitar face-down on a soft and clean surface.
  4. Schecter Demon-7 Pickup Selector Switch Replacement: passo 4, immagine 1 di 2 Schecter Demon-7 Pickup Selector Switch Replacement: passo 4, immagine 2 di 2
    • If the guitar has active pickups, open the battery tray and remove the 9-volt battery.
  5. Schecter Demon-7 Pickup Selector Switch Replacement: passo 5, immagine 1 di 2 Schecter Demon-7 Pickup Selector Switch Replacement: passo 5, immagine 2 di 2
    • Remove the large plastic backing plate.
  6. Schecter Demon-7 Pickup Selector Switch Replacement: passo 6, immagine 1 di 2 Schecter Demon-7 Pickup Selector Switch Replacement: passo 6, immagine 2 di 2
    • Carefully pull the pickup selector switch out of the body of the guitar.
  7. Schecter Demon-7 Pickup Selector Switch Replacement: passo 7, immagine 1 di 1
    • Switch the pickup selector switch to the side that does not work.
    • If neither side works, then repeat the next step on each side.
  8. Schecter Demon-7 Pickup Selector Switch Replacement: passo 8, immagine 1 di 2 Schecter Demon-7 Pickup Selector Switch Replacement: passo 8, immagine 2 di 2
    • Insert the sandpaper into the switch and proceed to scuff the contacts. Be sure to flip the sandpaper and scuff each side of the contact.
  9. Schecter Demon-7 Pickup Selector Switch Replacement: passo 9, immagine 1 di 1
    • Insert the switch back into the guitar, ensure that the switch is in the correct orientation.
Conclusione
2 Commenti
Never thought of this method. Having the same problem with my son’s Demon 7 so the only solution I could think of was to buy a new switch but I can’t find the exact one. I’ll try this trick instead. Thanks!
Seth - Replica
This worked great and exactly what I needed to fix my pickup selector switch on my Schector Omen 6. Though this should work for any pickup selector switch I'd think. I was getting intermittent issues and sometimes couldn't get the Bridge position to work at all. I was fearful I'd have to replace, so tried this first, and worked like a charm! Sounds perfect again, no new switch needed. Thank you.
Justin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 40
Tutti i Tempi: 2,745
