Salta al contenuto principale
Sceptre X9 Komodo VII Board Cover Replacement
Cosa ti serve
  1. Sceptre X9 Komodo VII Board Cover Replacement, Stand: passo 1, immagine 1 di 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Board Cover Replacement: passo 2, immagine 1 di 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Board Cover Replacement, Board Cover: passo 3, immagine 1 di 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Board Cover Replacement: passo 4, immagine 1 di 3 Sceptre X9 Komodo VII Board Cover Replacement: passo 4, immagine 2 di 3 Sceptre X9 Komodo VII Board Cover Replacement: passo 4, immagine 3 di 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Board Cover Replacement: passo 5, immagine 1 di 2 Sceptre X9 Komodo VII Board Cover Replacement: passo 5, immagine 2 di 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
Conclusione
Ted Hsueh
Membro da: 09/20/12
170 Reputazione
3 Guide realizzate
Cal Poly, Team 16-56, Forte Fall 2012 Membro di Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 11
Tutti i Tempi: 466
