Salta al contenuto principale
Satellite Pro L650 RAM Replacement
Cosa ti serve
  1. Satellite Pro L650 RAM Replacement, Remove Battery: passo 1, immagine 1 di 2 Satellite Pro L650 RAM Replacement, Remove Battery: passo 1, immagine 2 di 2
    • (Right Side-Image 1) Pull clip outwards until it sticks
    • (Left side-Image 1/2) While pulling clip outwards, pull the battery with your other hand.
    • When re-assembling, push the battery in then engage right clip (red box)
  2. Satellite Pro L650 RAM Replacement: passo 2, immagine 1 di 2 Satellite Pro L650 RAM Replacement: passo 2, immagine 2 di 2
    • (Image 1) Unscrew the screw with a Phillips Head #00
    • (Image 2) Two clips are located at the top. Dissengage them and lift the panel.
    • A spudger can be used, but is not required.
    • When re-assembling, put the clips of the cover in first, then screw
    • Push the clips on the side out
    • Pull the RAM out of the slot
    • Only hold the RAM from the side
    • When re-assembling, make sure to put the RAM the right way up. Insert it into the slot then push down.
Conclusione
To reassemble your device, follow these instructions in reverse order. See the Reminder boxes, located at the bottom of each step, for certain reassembly instructions.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 47
Tutti i Tempi: 195
