Salta al contenuto principale
Sapphire Nitro+ RX 6800 XT SE Fan Replacement
Cosa ti serve
  1. Sapphire Nitro+ RX 6800 XT SE Fan Replacement, ARGB Fans: passo 1, immagine 1 di 1
    • Unscrew the JIS000 screw securing the fan to the graphics card
  2. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 2, immagine 1 di 1
    • Lift the fan from the top and pull away from you.
  3. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 3, immagine 1 di 1
    • Clean any dust or residue present with a Q-tip damp with alcohol.
  4. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 4, immagine 1 di 1
    • Flip the fan over and notice the pins on the fan and in the graphics card fan slot:
    • Fan Pins
    • Fan slot
    • Flip the fan back over keeping the same orientation and carfully insert the fan.
    • If inserted incorrectly the pins could bend or break!
  5. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 5, immagine 1 di 1
    • Push the fan toward you to ensure that the pins are connected.
  6. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 6, immagine 1 di 1
    • Rescrew the JIS000 screw in the top of the fan.
    • Repeat steps 1 - 5 on the remaining fans if needed.
    • The center fan has a unique fan sicker to designate it as the middle.
Conclusione
After assembly, the fans and RGB will work like new!
Weston Wood
Membro da: 10/23/23
183 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 42
Tutti i Tempi: 356
