Parti
Nessuna parte richiesta.
Power down the phone by holding down the red "end" button.
  • Power down the phone by holding down the red "end" button.
Aggiungi Commento
Push and hold the button on the back toward the direction of the arrow to unlock the battery.
  • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
  • Lift and remove the battery from the back of the phone.
Aggiungi Commento
  • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
Aggiungi Commento
  • Unscrew all four, 5mm Tri-Wing screws.
Aggiungi Commento
  • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
  • This step may require extra force. But too much force could break the back casing.
  • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
Aggiungi Commento
  • Gently lift up the motherboard. The keypad should now be exposed.
Aggiungi Commento
  • Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
Aggiungi Commento
  • Remove the motherboard from the back of the phone.
Aggiungi Commento
Conclusione
Michaella
Membro da: 07/10/2014
97 Reputazione
1 Guida realizzata
USF Tampa, Team 1-6, Leahy Fall 2014 Membro di USF Tampa, Team 1-6, Leahy Fall 2014
USFT-LEAHY-F14S1G6
6 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 157
