Salta al contenuto principale
Sanyo VPC-X1200 Button Plate Replacement
Cosa ti serve
    1. Sanyo VPC-X1200 Button Plate Replacement, Back Case: passo 1, immagine 1 di 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: passo 1, immagine 2 di 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: passo 1, immagine 3 di 3
      • Remove the five case screws with a Phillips #00 Screwdriver.
      • Five 3.5mm Phillips Screws
      Chiedi a FixBot
      Aggiungi Commento
    2. Sanyo VPC-X1200 Button Plate Replacement: passo 2, immagine 1 di 1
      • Gently lift up the back cover and set aside.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: passo 3, immagine 1 di 2 Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: passo 3, immagine 2 di 2
      • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
      • Be careful not to rip out the ribbon connector.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sanyo VPC-X1200 Button Plate Replacement: passo 4, immagine 1 di 2 Sanyo VPC-X1200 Button Plate Replacement: passo 4, immagine 2 di 2
      • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
      • Gently lift ribbon out of the gate and set screen aside.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sanyo VPC-X1200 Button Plate Replacement, Button Plate: passo 5, immagine 1 di 2 Sanyo VPC-X1200 Button Plate Replacement, Button Plate: passo 5, immagine 2 di 2
      • There are five screws of three different sizes which need removal.
      • One 4.5mm screw
      • Four 3.5mm screws, one on the button side
      • One 5.5mm screws
      Chiedi a FixBot
      Aggiungi Commento
    2. Sanyo VPC-X1200 Button Plate Replacement: passo 6, immagine 1 di 2 Sanyo VPC-X1200 Button Plate Replacement: passo 6, immagine 2 di 2
      • Slowly lift metal tray to the right.
      • Be careful not to bend the screw tabs or rip out the ribbon cable.
      • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 7-10, Maness Spring 2010 Membro di Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Membri
23 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 27
Tutti i Tempi: 2,653
