Salta al contenuto principale
Sanyo VPC-X1200 Button Plate Replacement
Cosa ti serve
  1. Sanyo VPC-X1200 Button Plate Replacement, Back Case: passo 1, immagine 1 di 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: passo 1, immagine 2 di 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: passo 1, immagine 3 di 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 Button Plate Replacement: passo 2, immagine 1 di 1
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: passo 3, immagine 1 di 2 Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: passo 3, immagine 2 di 2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 Button Plate Replacement: passo 4, immagine 1 di 2 Sanyo VPC-X1200 Button Plate Replacement: passo 4, immagine 2 di 2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 Button Plate Replacement, Button Plate: passo 5, immagine 1 di 2 Sanyo VPC-X1200 Button Plate Replacement, Button Plate: passo 5, immagine 2 di 2
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 Button Plate Replacement: passo 6, immagine 1 di 2 Sanyo VPC-X1200 Button Plate Replacement: passo 6, immagine 2 di 2
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
Conclusione
Cal Poly, Team 7-10, Maness Spring 2010 Membro di Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,224
