Salta al contenuto principale
Sanyo VPC-T850 Outer Casing Replacement
Cosa ti serve
  1. Sanyo VPC-T850 Outer Casing Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Outer Casing Replacement: passo 2, immagine 1 di 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Outer Casing Replacement: passo 3, immagine 1 di 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Outer Casing Replacement: passo 4, immagine 1 di 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Outer Casing Replacement, Outer Casing: passo 5, immagine 1 di 3 Sanyo VPC-T850 Outer Casing Replacement, Outer Casing: passo 5, immagine 2 di 3 Sanyo VPC-T850 Outer Casing Replacement, Outer Casing: passo 5, immagine 3 di 3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Outer Casing Replacement: passo 6, immagine 1 di 2 Sanyo VPC-T850 Outer Casing Replacement: passo 6, immagine 2 di 2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Outer Casing Replacement: passo 7, immagine 1 di 1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Outer Casing Replacement: passo 8, immagine 1 di 2 Sanyo VPC-T850 Outer Casing Replacement: passo 8, immagine 2 di 2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Outer Casing Replacement: passo 9, immagine 1 di 1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
Conclusione
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 144
