Cosa ti serve
Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
Flip the device over to where the display is located.
Using your plastic opening tool, lift the display out of its metal housing.
Orient the camera so the lens is facing up.
Locate and remove the two screws connecting the lens to the camera.
