Salta al contenuto principale
Sanyo VPC-T850 Lens Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Sanyo VPC-T850 Lens Replacement, Disassembling Sanyo VPC-T850 Outer Casing: passo 1, immagine 1 di 1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Sanyo VPC-T850 Lens Replacement, Remove Screws: passo 2, immagine 1 di 3 Sanyo VPC-T850 Lens Replacement, Remove Screws: passo 2, immagine 2 di 3 Sanyo VPC-T850 Lens Replacement, Remove Screws: passo 2, immagine 3 di 3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Sanyo VPC-T850 Lens Replacement, Remove Rear Panel: passo 3, immagine 1 di 3 Sanyo VPC-T850 Lens Replacement, Remove Rear Panel: passo 3, immagine 2 di 3 Sanyo VPC-T850 Lens Replacement, Remove Rear Panel: passo 3, immagine 3 di 3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Sanyo VPC-T850 Lens Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Sanyo VPC-T850 Lens Replacement: passo 5, immagine 1 di 1
    • Separate the rear panel from the rest of the camera.
  6. Sanyo VPC-T850 Lens Replacement: passo 6, immagine 1 di 2 Sanyo VPC-T850 Lens Replacement: passo 6, immagine 2 di 2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Sanyo VPC-T850 Lens Replacement: passo 7, immagine 1 di 2 Sanyo VPC-T850 Lens Replacement: passo 7, immagine 2 di 2
    • Carefully pull off the side covers wrapped around the camera.
  8. Sanyo VPC-T850 Lens Replacement, Remove Front Cover: passo 8, immagine 1 di 3 Sanyo VPC-T850 Lens Replacement, Remove Front Cover: passo 8, immagine 2 di 3 Sanyo VPC-T850 Lens Replacement, Remove Front Cover: passo 8, immagine 3 di 3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
  9. Sanyo VPC-T850 Lens Replacement, Disconnect the Ribbon: passo 9, immagine 1 di 2 Sanyo VPC-T850 Lens Replacement, Disconnect the Ribbon: passo 9, immagine 2 di 2
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  10. Sanyo VPC-T850 Lens Replacement, Remove LCD Screen: passo 10, immagine 1 di 1
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
  11. Sanyo VPC-T850 Lens Replacement, Lens: passo 11, immagine 1 di 1
    • Flip the camera over with the lens facing up.
  12. Sanyo VPC-T850 Lens Replacement: passo 12, immagine 1 di 1
    • Using the Phillips #00 Screwdriver, remove the two screws holding the lens in place.
    • Use your other hand to hold the lens in place so the lens does not fall out while removing the screws.
  13. Sanyo VPC-T850 Lens Replacement: passo 13, immagine 1 di 2 Sanyo VPC-T850 Lens Replacement: passo 13, immagine 2 di 2
    • While keeping hold of the lens, flip the entire assembly around.
    • Using your fingers, gently push the lens out from its position in the casing.
    • There is still a flat, golden wire connecting the lens to the motherboard.
  14. Sanyo VPC-T850 Lens Replacement: passo 14, immagine 1 di 2 Sanyo VPC-T850 Lens Replacement: passo 14, immagine 2 di 2
    • Carefully unplug the golden wire from the motherboard to remove the lens from the assembly.
Linea Traguardo
Jonathan Yau
Membro da: 04/11/10
26 Reputazione
4 Guide realizzate
Cal Poly, Team 27-95, Amido Spring 2010 Membro di Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,887
