Salta al contenuto principale
Sanyo VPC-T850 LCD Display Replacement
Cosa ti serve
  1. Sanyo VPC-T850 LCD Display Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 LCD Display Replacement: passo 2, immagine 1 di 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 LCD Display Replacement: passo 3, immagine 1 di 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 LCD Display Replacement: passo 4, immagine 1 di 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 LCD Display Replacement, Outer Casing: passo 5, immagine 1 di 3 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: passo 5, immagine 2 di 3 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: passo 5, immagine 3 di 3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 LCD Display Replacement: passo 6, immagine 1 di 2 Sanyo VPC-T850 LCD Display Replacement: passo 6, immagine 2 di 2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 LCD Display Replacement: passo 7, immagine 1 di 1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 LCD Display Replacement: passo 8, immagine 1 di 2 Sanyo VPC-T850 LCD Display Replacement: passo 8, immagine 2 di 2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 LCD Display Replacement: passo 9, immagine 1 di 1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 LCD Display Replacement, LCD Display: passo 10, immagine 1 di 1
    • Flip the device over to where the display is located.
    • Using your plastic opening tool, lift the display out of its metal housing.
  11. Sanyo VPC-T850 LCD Display Replacement: passo 11, immagine 1 di 1
    • Locate the orange ribbon connecting the display to the camera.
    • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
  12. Sanyo VPC-T850 LCD Display Replacement: passo 12, immagine 1 di 1
    • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
    • Pull slowly to avoid severing the orange ribbon from the display.
Conclusione
Devin Farnsworth
Membro da: 10/29/15
101 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 498
