Salta al contenuto principale
Sanyo VPC-S1415 LCD Replacement
Cosa ti serve
  1. Sanyo VPC-S1415 LCD Replacement, LCD: passo 1, immagine 1 di 3 Sanyo VPC-S1415 LCD Replacement, LCD: passo 1, immagine 2 di 3 Sanyo VPC-S1415 LCD Replacement, LCD: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Here is a recently acquired camera. Initial cost $3.00
    • Only trouble is, obviously broken LCD
    • Remove the carrying strip. Use a needle and some tweezers to loosen the slip knot.
  2. Sanyo VPC-S1415 LCD Replacement: passo 2, immagine 1 di 3 Sanyo VPC-S1415 LCD Replacement: passo 2, immagine 2 di 3 Sanyo VPC-S1415 LCD Replacement: passo 2, immagine 3 di 3
    • Remove one screw on the right of the camera
    • Remove one screw on the left side of the camera
    • Remove the two screws on the bottom
  3. Sanyo VPC-S1415 LCD Replacement: passo 3, immagine 1 di 3 Sanyo VPC-S1415 LCD Replacement: passo 3, immagine 2 di 3 Sanyo VPC-S1415 LCD Replacement: passo 3, immagine 3 di 3
    • Split the camera from the battery compartment down. You can use an opening tools, or just your fingernails, if so equipped.
    • This will remove the front part of the case.
    • Remove this screw on the right side of the camera. Keep it separate from the 4 screws previously removed. The are of different length
  4. Sanyo VPC-S1415 LCD Replacement: passo 4, immagine 1 di 3 Sanyo VPC-S1415 LCD Replacement: passo 4, immagine 2 di 3 Sanyo VPC-S1415 LCD Replacement: passo 4, immagine 3 di 3
    • Remove the screw on the bottom of the battery compartment. Keep this screw with the one removed on the previous step. These two screws have a different length than all the other screws. They are the shortest ones in the camera
    • With those two screws removed, you can not separate the back part of the case.
    • Flip the LCD to the right and out of the frame. Do NOT try to remove it yet.
    • Remove the screw screws that hold the LCD frame to the logic board. Keep the 3 screws separated from the rest of the screws, due to different length.
  5. Sanyo VPC-S1415 LCD Replacement: passo 5, immagine 1 di 3 Sanyo VPC-S1415 LCD Replacement: passo 5, immagine 2 di 3 Sanyo VPC-S1415 LCD Replacement: passo 5, immagine 3 di 3
    • With the frame removed, the connector and LCD cable are now fully accessible. Note the to tabs on the cable and their position on the logic board.
    • Flip the tab on the connector carefully up and remove the LCD.
    • Hopefully this is what you will get after replacing the LCD and reassembling the camera in reverse order. Total replacement cost was $15 and 30 minutes of my time.
Conclusione
oldturkey03
Membro da: 09/29/10
836.996 Reputazione
123 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,329
