Salta al contenuto principale
Introduzione
Use this guide to remove or replace the case.
Parti
Nessuna parte specificata.
  1. Place your thumb on the right side of the camera over the battery door.
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Remove and recycle old batteries.
    • Remove and recycle old batteries.
  3. Remove the following six screws using the Phillips #00 screwdriver: Two screws on the left side of the camera. Two screws on the right side of the camera.
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  5. Open the battery slot on the bottom of the camera by sliding the door to the right. Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  6. Insert a spudger in the seam at the bottom of the camera. Gently separate the rear case from the front of the camera. Gently separate the rear case from the front of the camera.
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  7. This step is only needed for the case and logic board replacement
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  8. This step is only needed for the case replacement.
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
Conclusione
Ariana Martinez
Membro da: 15/04/2010
50 Reputazione
4 Guide realizzate
Cal Poly, Team 24-24, Regan Spring 2010 Membro di Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,779
