Salta al contenuto principale
Sanyo SCP-8100 Speaker Replacement
Cosa ti serve
  1. Sanyo SCP-8100 Speaker Replacement, Battery: passo 1, immagine 1 di 3 Sanyo SCP-8100 Speaker Replacement, Battery: passo 1, immagine 2 di 3 Sanyo SCP-8100 Speaker Replacement, Battery: passo 1, immagine 3 di 3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Sanyo SCP-8100 Speaker Replacement, Back Panel: passo 2, immagine 1 di 2 Sanyo SCP-8100 Speaker Replacement, Back Panel: passo 2, immagine 2 di 2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Sanyo SCP-8100 Speaker Replacement: passo 3, immagine 1 di 1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Sanyo SCP-8100 Speaker Replacement: passo 4, immagine 1 di 2 Sanyo SCP-8100 Speaker Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Sanyo SCP-8100 Speaker Replacement: passo 5, immagine 1 di 3 Sanyo SCP-8100 Speaker Replacement: passo 5, immagine 2 di 3 Sanyo SCP-8100 Speaker Replacement: passo 5, immagine 3 di 3
    • While removing the back panel, take out the rubber cover on each side.
  6. Sanyo SCP-8100 Speaker Replacement, Speaker: passo 6, immagine 1 di 2 Sanyo SCP-8100 Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Pull the connector at the top of the back panel out.
    • You may need to use some force when pulling.
    • It may still be connected to the phone instead of the back panel.
  7. Sanyo SCP-8100 Speaker Replacement: passo 7, immagine 1 di 2 Sanyo SCP-8100 Speaker Replacement: passo 7, immagine 2 di 2
    • Use the opening tool to lift the speaker out from the right side.
Conclusione
Paul Truong
Membro da: 04/15/13
1 Reputazione
2 Guide realizzate
Cal Poly, Team 10-41, Amido Spring 2013 Membro di Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 383
