Introduzione
Once the motherboard has been remove from the bottom of the phone, it is possible to peel the keyboard off the front of the motherboard to be replaced.
Parti
Nessuna parte richiesta.
Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
  • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
  • While holding down the button, pull cover off with other hand.
Aggiungi Commento
Use fingers to grip the battery and remove it from the phone.
  • Use fingers to grip the battery and remove it from the phone.
Aggiungi Commento
  • Using a spudger, remove the four rubber coverings on the lower back plate.
Aggiungi Commento
  • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
Aggiungi Commento
  • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
Aggiungi Commento
  • Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver.
Aggiungi Commento
  • For the following steps, the phone is shown closed to make manipulating the parts easier.
  • Using a spudger, remove the thin aluminum plate to access the upper motherboard.
    • This will most likely be difficult to pry off and will take a considerable amount of force. Stay clear of the piece to avoid injury when it comes free of the device.
Aggiungi Commento
  • Use the flat end of the spudger to remove two ribbon cables from the back of the motherboard.
Aggiungi Commento
  • Open the phone and firmly hold the phone casing with one hand and push the motherboard out of the case with the other by pushing on the keys.
  • Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers.
Aggiungi Commento
  • Carefully peel the rubber keypad mat off of the motherboard. The keypad is secured with an adhesive material, so there will be slight resistance.
Aggiungi Commento
Conclusione
Preston
Membro da: 11/03/2013
216 Reputazione
10 Guide realizzate
Clemson, Team 12-1, Benson Spring 2013 Membro di Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 175
