Introduzione
This guide will illustrate for you how to replace the battery from a Sanyo Katana Eclipse X.
Parti
Nessuna parte richiesta.
  1. Press the battery release button located on the back of the phone. With the button depressed, pull down on the battery protector to remove it from the phone.
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
      • The phone's battery will now be exposed.
  2. Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
      • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
    • Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
      • Refer to photo illustrations.
    • Using your thumb, apply gentle pressure to the battery until it clicks into place.
  5. Take the phone’s back casing and set it over the battery.
    • Take the phone’s back casing and set it over the battery.
    • Apply gentle pressure, pushing towards the top of the phone until your hear a click.
Conclusione
Thomas Scaggs
Membro da: 15/10/2012
209 Reputazione
2 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 257
