Salta al contenuto principale
Sanyo Katana Camera Replacement
Cosa ti serve
  1. Sanyo Katana Camera Replacement, Screen Protector: passo 1, immagine 1 di 2 Sanyo Katana Camera Replacement, Screen Protector: passo 1, immagine 2 di 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Camera Replacement: passo 2, immagine 1 di 2 Sanyo Katana Camera Replacement: passo 2, immagine 2 di 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Camera Replacement: passo 3, immagine 1 di 2 Sanyo Katana Camera Replacement: passo 3, immagine 2 di 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Camera Replacement, Front Case: passo 4, immagine 1 di 3 Sanyo Katana Camera Replacement, Front Case: passo 4, immagine 2 di 3 Sanyo Katana Camera Replacement, Front Case: passo 4, immagine 3 di 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
  5. Sanyo Katana Camera Replacement, Camera: passo 5, immagine 1 di 3 Sanyo Katana Camera Replacement, Camera: passo 5, immagine 2 di 3 Sanyo Katana Camera Replacement, Camera: passo 5, immagine 3 di 3
    • Use a Tri-wing Y0 screwdriver to remove the 4.4mm screw.
    • Use fingers to remove the strip.
  6. Sanyo Katana Camera Replacement: passo 6, immagine 1 di 3 Sanyo Katana Camera Replacement: passo 6, immagine 2 di 3 Sanyo Katana Camera Replacement: passo 6, immagine 3 di 3
    • Detach the ribbon connections underneath the green connector strip and remove them from the device. This will reveal the camera.
  7. Sanyo Katana Camera Replacement: passo 7, immagine 1 di 3 Sanyo Katana Camera Replacement: passo 7, immagine 2 di 3 Sanyo Katana Camera Replacement: passo 7, immagine 3 di 3
    • Using a spudger, remove the ribbon connection of the camera from the adhesive that attaches it to the device.
    • Grab the camera using fingers and remove it from the phone case.
Conclusione
Preston
Membro da: 03/11/13
216 Reputazione
5 Guide realizzate
Clemson, Team 12-1, Benson Spring 2013 Membro di Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 308
