Salta al contenuto principale
Sansa e260R Memory Board Replacement
Cosa ti serve
  1. Sansa e260R Memory Board Replacement, Rear Case: passo 1, immagine 1 di 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Memory Board Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Memory Board Replacement: passo 3, immagine 1 di 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Memory Board Replacement, Battery: passo 4, immagine 1 di 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Memory Board Replacement, Front Panel: passo 5, immagine 1 di 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Memory Board Replacement: passo 6, immagine 1 di 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Memory Board Replacement: passo 7, immagine 1 di 2 Sansa e260R Memory Board Replacement: passo 7, immagine 2 di 2
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Memory Board Replacement, Memory Board: passo 8, immagine 1 di 2 Sansa e260R Memory Board Replacement, Memory Board: passo 8, immagine 2 di 2
    • Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
    • Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
  9. Sansa e260R Memory Board Replacement: passo 9, immagine 1 di 1
    • Pull the bottom of the motherboard up and then out.
  10. Sansa e260R Memory Board Replacement: passo 10, immagine 1 di 1
    • On the back of the motherboard, there is a rectangle of rubber.
    • Peel the rectangle off slowly.
  11. Sansa e260R Memory Board Replacement: passo 11, immagine 1 di 1
    • Under the rubber rectangle, there is a strip of black tape.
    • Peel the tape off about halfway so that it is no longer attached to the memory board.
  12. Sansa e260R Memory Board Replacement: passo 12, immagine 1 di 1
    • Carefully peel the memory board away from the rest of the motherboard
Conclusione
Altre 6 persone hanno completato questa guida.
JenniferW
Membro da: 01/31/12
194 Reputazione
2 Guide realizzate
Cal Poly, Team 8-15, Maness Winter 2012 Membro di Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Membri
5 Guide realizzate
Un commento
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
Admin User - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,569
