Salta al contenuto principale
Sansa e260R Front Panel Replacement
Cosa ti serve
  1. Sansa e260R Front Panel Replacement, Rear Case: passo 1, immagine 1 di 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Front Panel Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Front Panel Replacement: passo 3, immagine 1 di 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Front Panel Replacement, Battery: passo 4, immagine 1 di 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Front Panel Replacement, Front Panel: passo 5, immagine 1 di 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Front Panel Replacement: passo 6, immagine 1 di 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Front Panel Replacement: passo 7, immagine 1 di 2 Sansa e260R Front Panel Replacement: passo 7, immagine 2 di 2
    • Pull the front cover away from the rest of the device.
Conclusione
Casey Smith
Membro da: 01/20/12
111 Reputazione
3 Guide realizzate
Cal Poly, Team 8-15, Maness Winter 2012 Membro di Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,966
