Parti
Nessuna parte richiesta.
  1. Before disassembling the device, make sure it is powered off.
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Using a plastic opening tool, lift the metal backing from the front of the device.
    • Using a plastic opening tool, lift the metal backing from the front of the device.
    • Pull the rear panel off of the Sansa e260R.
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
    • Pull the front cover away from the rest of the device.
Conclusione
Casey Smith
Membro da: 20/01/2012
99 Reputazione
3 Guide realizzate
Cal Poly, Team 8-15, Maness Winter 2012 Membro di Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,733
