Parti
Nessuna parte richiesta.
  1. Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • To ensure you don't lose any tiny parts during the replacement process, place parts on the white magnetic sheet.
    • Once the screws have been removed, proceed to take off back cover.
  2. Now, proceed to lift the battery out and remove it.
    • Now, proceed to lift the battery out and remove it.
  3. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
    • Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
    • Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
  6. Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary. Pull the motherboard out and down away from the top of the phone.
    • Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary.
    • Pull the motherboard out and down away from the top of the phone.
  7. Peel off the small foam rectangle on the back of the mainboard and set to the side.
    • Peel off the small foam rectangle on the back of the mainboard and set to the side.
    • Peel off the black tape and set off to the side.
  8. Gently pry up the memory chip and replace it with the new one.
    • Gently pry up the memory chip and replace it with the new one.
Conclusione
Altre 2 persone hanno completato questa guida.
Lauren
Membro da: 13/02/2014
43 Reputazione
2 Guide realizzate
Ohio State, Team 1-4, Buehl Spring 2014 Membro di Ohio State, Team 1-4, Buehl Spring 2014
OSU-BUEHL-S14S1G4
3 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 603
