Salta al contenuto principale
Sanitaire SC684 Roller Brusher and Drive Belt Replacement
  1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement, Roller Brush and Belt: passo 1, immagine 1 di 1
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay the vacuum on its back.
  2. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 2, immagine 1 di 1
    • Find the metal plate (located directly in the center).
    • Locate the two latches on either side of the metal plate.
    • Detach the latches by pulling them away from metal plate.
  3. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 3, immagine 1 di 1
    • Remove the metal plate by pulling it towards you.
  4. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 4, immagine 1 di 1
    • Identify the belt and brush roller.
    • The belt is a black ring made of rubber.
    • The brush roller is the long metal tube with bristles attached to it.
  5. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 5, immagine 1 di 1
    • Remove the belt from the circular knob by inserting your fingers on either side, gently lifting towards you.
  6. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 6, immagine 1 di 2 Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 6, immagine 2 di 2
    • Pull brush roller out and slip the belt off from the indent in the middle of the roller.
Conclusione
Caycie Pascual
Membro da: 09/26/12
1 Reputazione
4 Guide realizzate
Cal Poly, Team 16-58, Forte Fall 2012 Membro di Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,793
