Strumenti
Nessun attrezzo richiesto.
  1. Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Lift off the metal plate by pulling it towards you.
    • Lift off the metal plate by pulling it towards you.
  5. Identify the belt and brush roller.
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
  6. Slide the belt off of the circular knob.
    • Slide the belt off of the circular knob.
  7. Pull brush roller out and detach the belt off the brush roller. Pull brush roller out and detach the belt off the brush roller.
    • Pull brush roller out and detach the belt off the brush roller.
Conclusione
Caycie Pascual
Membro da: 26/09/2012
1 Reputazione
5 Guide realizzate
Cal Poly, Team 16-58, Forte Fall 2012 Membro di Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 836
